Hi guys - little problem i'm hoping somone can help me with.
I've had my xbox pads and wireless battery charger kits for a while now, but i've noticed that the light on the charger doesn't light up anymore and now my battery's dead
Am i right in thinking that if i plug the charger into the pad without the battery, the pad should connect because there is a physical connection?
If both of my chargers now don't work, would the best option be to buy a quick charge kit to charge my batteries up and then put them into my pads?
Thanks
Viks
!Am i right in thinking that if i plug the charger into the pad without the battery, the pad should connect because there is a physical connection?
Thanks
Viks
plus the quick charge is quicker to charge surprisingly enough!
