Xbox 360 problem
The Xbox should do this if it's too hot, it spend 15-30 seconds or so to cool down the components before fully turning off. So this could be it is too hot around your Xbox and it will never cool down. So just try it at another location for an hour or so first :)
Or the heat sensor is broken so it always thinks it's hot maybe?
Well it was DOA then cause it's happened since I unpacked it, I'm gonna give them a ring tonight I'll update people ok :). Thanks for all your help hopefully I get this sorted.
Sorry for the double post, I went down there within 10 mins of phoning them and now have another brand new quiet 360 :) it's stopped doing the fans stuff.
mine does this loads i just press the power off again or turn it off at the wall on my way out!
