xbox 360 S & Kinect lock ups ?
CSA
CSA
20 Apr 2006
Lancashire
Ive only had it a couple of weeks but ive had about 4 hard lock ups,TV screen goes black and i have to press OFF several times before the console will actually turn off
any one suffered this with a new Slim model ?
I think it's because the kinect uses the power from the slim and it isn't an external power brick = more heat on xbox ?
You know I can't even remember how i connected mine. I think I did connect it into some external power as well as the back of the slim? Since I had to shuffle around the back of my unit.. But anyway I can tell you, I've not had any locks whatsoever. So YES something is amiss with your setup.
kk i'll add the external power supply and see if that helps :)
I've got a Slim with Kinect just connected via the custom lead and I've not had a problem.
You only need the external power lead if you're using Kinect with an old 360.
yeah i thought that, worth a try tho
