Xbox 360 Save data on memory stick?
what happens with that is that it would require to wipe the whole drive (so backup the whole 250GB) and then it makes a drive with 16GB or so on it within the 250GB physical space. afterwards you can then go make a FAT32/NTFS system with the rest afterwards.
Perfect, Cheers.
Been looking around also at just whacking a 2.5" drive in the Xbox. Everywhere says its a special ms drive, But I've looked in and its just bog standard sata connectors. Will get a 2.5" drive, If it doesn't work, Can always use it as an external for both Xbox and PC.
yea i believe it has to be a certain drive you need to use, personally i wouldnt bother, you can nip into local gaming shops and find a 250GB hdd (usable in the core/premium and elite but not the new S and arcade 4GB) for £50-60.
better off to save an extra £30-£40 and get the 250GB slim tbh only advantage to the new 4GB is its matt and not gloss. my mates console looks dirty like smudge marks although it doesnt look scratched.
I've already got the 4gb now ;) The 250gb wasn't worth the extra £65.
4gb is plenty. If I do run out, An external hard drive will be bought for a lot cheaper than what MS would charge for it.
£65? you got your arcade 4GB for £120 roughly? nice price and in that case i cant blame you for doing that.
reason i prefer the bigger space is for game installs mostly.
£130, Still a bargain I'd say.
Previously had a 60gb model and used the space for installing them, But on that one it was a must. This model its pretty damn quiet.
