been messing about tonight with my setup between hdmi and vga on my Sony HDTV, I was just wondering what the concensus is around here of which one you find better, Im leaning towards VGA at the moment i think, agee disagree??
can only think you have been trying Crap HD leads
Well the Offical one I got was Crap compared to the one I got from my mates shop, The difference is like chalk & cheese & I likes me cheese. I Honestly can't think of another reason anybody would say that as I ran VGA before I got the HD lead & it sucked the big one.
Just thought
You lot,
"Should have gone to Spec Savers"![]()
I got a 40 inch 5 series Samsung delivered to my door on Xmas eve I doubt the VGA socket suxs, I also have the Offical Microsft HD lead but that sucks compared to the one I use.
Honestly I can only think & say, What the **** !!!
Unless one is broken and you are getting a corrupted image there should no difference between HDMI leads. They don't work like old analogue cables, either the signal got there or it didn't and if it didn't, then it will ruin the picture (like big square blocky corruption).
Have heard & discussed this plenty mate but honestly there is a difference & a Big one between the two leads, No blocks either just a crap picture. Confuses me but I don't care since the lead & picture I use now is Awesome.
Hi
I also found VGA to be better on my samsung 46" than via HDMI.
VGA looks more natural to me and does a better job of removing the jaggies in games maybe its because Vga has a slightly softer look to it imo.
