Xbox 360 true power?
I usually run my games on a 36 inch HDTV at 1080i, is 720p better?
That's a bit random and a bit too sensible for this thread! It depends on the native resolution of your TV, so if you TV has 1366 x 768 Resolution then it's possible that 720p will look better as it's closer to the actual resolution of the screen so no upscaling is needed. However, if your TV has a really good upscaler chip then it could look better in 1080i - I guess you should just try them both and see which you prefer.
What Joebob said, I have a set of the same resolution and 1080i looks best but I have seen other sets of the same res that look better at 720p.
Going back to the OP, what's the point in building custom CPU's for consoles anyway? Surely just using an off the shelf processor would be cheaper to implement and easier to program for?
....ah sod it!!!......
