- 8 Apr 2004
Hi, I'm thinking of getting a KVM switch so that I can use my TFT with my PC and 360 without having to switch cables but I have a question that I haven't been able to have answered. If the end of the VGA cable and the end of the KVM cable that you should plug your console into have the exact same end (which looks like this one: http://img142.imageshack.us/my.php?image=vgacon9vm.jpg) then do I need a convertor or something? I'm not 100% sure that is the correct KVM cable end (no idea which is male or female!) as it's been years since I last used one but having checked the VGA slot on my graphics card, I'm pretty sure the KVM cable end would be the above.
When I first got the VGA cable, I was baffled how I would connect it to the monitor VGA cable as they had the same ends (as above) until I realised I could just plug it directly into the monitor itself. But now I'm wondering the above. Would I need a convertor to connect both ends, or does this depend on the KVM switch I'm getting? Hope I made sense. Regards
