Permabanned
- 26 Apr 2008
Hi! I've been lurking here for almost a year now so I finally decided to create an account
Ok, recently I've been thinking about purchasing a HD LCD TV, possibly this one when it is available: CLICK
Now the thing is my 360 doesn't have HDMI, so I'll be using VGA instead. I thought about buying another 360 to upgrade to HDMI but I've done some research and it seems the difference between VGA and HDMI is negligible or non existant especially at the lower HD resolutions and on anything less than 50". But it also seems to depend on the TV itself, apparently some have poor VGA support and so HDMI is clearly superior in those cases.
So I guess I'm asking if any of you use VGA through Samsung LCD TV's, how does it look and have you had any experience of both VGA and HDTV on that screen, if so how do they compare? It seems unlikely but I just want to make sure I'm not purchasing a TV which has poor VGA support (I'm guessing it will be more or less the same throughout the majority of LCD TV's from the same manufacturer).
Thankyou in advance!
