Xbox 360 Wireless Networking
29 Sep 2005
Hi,
I've just brought a premium Xbox 360, but don't particularly fancy they idea of shelling out £55ish on the official Microsoft network adaptor.
Can I buy any generic USB adaptor, or an I going to have to bend over and take it from Microsoft?.
If a generic adaptor will work, can someone recommend one plz?
Cheers
Chris
A generic USB wireless adapter will not work I'm afraid.
You have 3 options really:
Wired Connection
Microsoft Official Wireless
Wireless Bridge like these: here
Hi,
Unfortunately you will need to buy the official one.
I am in the same boat, having to spend £55 on one.
Rob
Wired Connection
Thanks for that, think I will probably go for a bridge, as I'm guessing they will have better range than the standard adaptor?
Chrus
I'm afraid it doesn't take other brand USB network cards but you could just buy a Wireless Bridge then use an ethernet cable. Save you a few bob and might be more useful.
Is it possible to run a cable from a wirelessly connected pc to the xbox, bridged maybe? (xbox is only going to be 6 foot from the pc)
yes. There is no bridging involved, just use ICS in windows it works fine.
Cheers, got a mate who wants me to set it up for his kids. I've never even used an xbox let alone played with the networking! :)
