Xbox 360 wireless
27 Dec 2003
What alternatives are there to the official 360 wireless adapter?
Can you get anything that slots into the usb port at the back wich you can then link up with a normal wireless router?
No other USB wifi dongle will work with the 360 - only the official Microsoft one.
The only other option you have is a ethernet wifi bridge, to connect via the 360's ethernet port.
Pretty much sums up your options.
The_One said:
So i basically need a wireles router such as netgear, linksys or the like and the 360 wireless adapter?
Or, stuff like: http://www.overclockers.co.uk/acatalog/Games_Adapters_Bridges.html
But, at the end of the day, it's probably best just to go for the Official Wireless Adapter and a wireless router. You can get the adapter for only £45 over here: http://www.kays.com/AgNet/product.a...ch=xbox+wireless&fh_eds=%df&fh_refview=search, cheapest I've seen it new anyway.
