is it possible? i cba lugging up another ethernet cable to plug my 360 into live, wondered if its possible to get a addon for the 360 that allows it to pick up wireless.
+1 For homeplugs. I use the ones from solwise - up to 85Mb and they are excellent. I have them plugged into plug extensions as the sockets on my wall are too low but still the performance is great. So easy to setup just plug them in and switch on.
if you've got a cable near by you could buy a cheap hub so it splits the cable then just buy two short ones for your xbox and what ever else was using the original one.
