It comes with a disk, you install the drivers. After that it's just plug and play![]()
For every game? BFBC2 is the one i want it for ideally...
I'm on XP.
Think it may be a different process whether its an "Xbox controller for Windows" or just an Xbox pad being used with the dongle.
I'm on XP.
i use a standard wired pad.
Most new games that you would expect to be pad compatible are so out of the box. I have just discovered xpadder which gives you complete control of the controllers button setting.
Tried xpadder on my normal pad. Had all the buttons mapped exactly how i needed them. Went to play BFBC2 but nothing. Not one button works.
My 360 controller worked fine with bfbc2 without needing to use anything like xpadder![]()
I was just testing it though. I would never play an fps with anything other than keyboard and mouse![]()
The controller for windows is just a 360 one bundled with the wireless dongle.
