I used ProtonVPN.
Presumably buying this 3 times and converting for £1 is the easier way to go and doesn't need VPNs? https://www.cdkeys.com/xbox-live/me...x-live-gold-membership-xbox-one-360-eu-cd-key My gamepass (previously done on a £1 Gold conversion) expires next week.
Yup.
I believe you can still convert it, but it's likely you won't get the trial price offer ie £1 it'll be £10.99, but it should convert. So make it worthwhile and convert 3 years worthI'm guessing this doesnt work after taking the £1 Ultimate deal? As in if I buy a years gold now, it wont become ultimate if that makes sense
Yup.
No.
You will need to buy a full month of GPU rather than using the £1 offer.
Why is that? I will do it when the GPU expires.
Is that why I get a error when I try to upgrade mine?The trial is only for accounts that have never had GPU.
Don't be scared of VPN's people
It's a bit of software to install and isn't complicated. I used ProtonVPN, install, select Brazil and you're done.
It's not being scared of using a VPN. It's a concern that it's effectively using a code for a region that we're not in, and the possible repercussions from Microsoft. Granted, I've never heard of something happening but I'm not sure I'm willing to risk my 15 year old Live account just to save some money.
