xbox hd cable help
4 Dec 2009
hi all i just bought a xbox and i want to get a hd cable for my hd tv. was wondering is there any didfference between the hdmi cable. or the cable with the vga connector. thanks
i have sony bravia 32 inch lcd.
VGA = Analogue (assuming you're talking about a 15pin VGA connector)
HDMI = Digital
*generally* HDMI should be better, but it will depend on how good your TV handles HDMI and VGA. If you have both cables, try both and see what you think.
