Xbox help.
fiveub's Slave
1 Sep 2007
OcUK HQ
Hi, my brother has an xbox. He has a problem though, whenever he wants to get online with it he has to plug the router out then back in. Is there any other way around this? Why is it doing this?
Thanks for any help..
Don't need to bump after just 1 hour ;)
Sounds like your router is playing up or there is a setting on it you need to allow.
Before you have to reset it, do the Xbox network test, and see what the Xbox doesn't like. If it tells you anything, that may give a clue to what is up with the router.
