Permabanned
- 23 Jan 2006
- Up a Tree...
hello,
im having great difficulty in trying to get my new xbox to connect through the ethernet using my laptop which is on wireless...
i tried using the automatic settings, but allways fail.
i tried using google to find a solution, there is a lot of good help on there,
but nothing i could get to work for me...
im using a Netgear router downstairs,
and i have a acer ferrari 3400 laptop which is on wireless, while i have my xbox 360 connected to it using the ethernet cable supplied with the xbox.
but its just not working,
when i try to go into the wireless settings on the laptop,
go - properties - advanced - allow internet connection sharing... all i keep getting is this error.
and when it does connect... i get this.
i tried doing it manually too.. but i just cant work it out.
i even reset the router to start fresh again, but no joy :/
anyone used there pc or laptop for there xbox live?
can you show me how, be much great if you can.
as my pc isnt working, and im bored without online gaming
cheers
cheers
