Xbox One Audio Help
5 Jul 2006
Hi,
My monitor doesn't have audio out or inbuilt speakers, id like to get audio coming out of my pc speakers, video will be through HDMI.
How can I achieve this?
Hello
Just buy yourself a digital to analog audio converter they are only a tenner on ebay ;)
They look like this :)
ok I have bought the above but im still missing cables.
Im using the Creative T40 Series II speakers btw.
I need a cable, a cable that will go from the red and white inputs on the converter to the back of the speakers, though I will need to be y-splitter to go into the back of my soundcard.....a creative z soundcard.
yep just got one of them, but still no audio on my xbox one out of my speakers
with the cabling as it is the speakers are fine through PC, but absolutely no audio out of xbox one.
My config is:-
1 - toslink from xbox one into audio converter
2 - 3.5mm ysplitter from speaker with one 3.5mm going into soundcard and the other into rca
Settings>Display & Sound>Optical Audio
Then there are a few options to try if I remember correctly.
Cant check mine at the moment as the ladies are watching TV.
