So, my launch 360 finally red ringed a little while ago and I decided to repair it myself, got rid of the x clamps and screwed it all back together, red ring gone and the console is working perfectly...
However the fans on the back were going crazy and were basically stuck on full blast the whole time making it quite unpleasant to actually play games on it. So I got some thermal compound thinking that it would solve the fan problem and diffuse the heat better. It worked and the fans became uber quiet...
However! Now it keeps freezing up and artefacting either after a few seconds or a few minutes. I've taken it apart and tried less thermal compound, more, different HS tension but still the same, not sure what I've done to cause this.
Any suggestions?
Any suggestions?
