- 27 Mar 2004
- Telford
i have jsut got one of these, but i cannot get it to select channel 1 which is what the wireless pad is on it must be really simple any ideas?
tried all that the manual suggested not workingMemphis said:Believe it or not, the manual does tell you how to get the 360 to pickup the headset.
ScarySquirrel said:I assumed he had read that before posting here. Which it appears he had.
.LadFromWales85 said:Yep, it can support four controllers and four headsets, but according to the manual you must pair the forth headset BEFORE the forth controller.
perfect, thanksfergie666 said:when i first tried to connect my wireless headset, it kept assigning it to quadrant 2. this kept happening while following the instructions in the manual
how i got it to work.....
turn on console via joypad, then just turn on the headset and it assigns itself to the joypad (quadrant 1) has worked like this since![]()
ScarySquirrel said:So dude, is it any good now you have it working? Recommened over the wired headset?
