XFX 5870 problem
22 Aug 2009
Nottingham
Im just wondering if my one/both my XFX 5870xt are showing problems building up. every now and again i seam to get a green screen, then a green screen with lines going down it. Is this this a problem or nothing but a glich? :confused:
using newest drivers.
I'm getting flickering green pixels in dark areas occasionally when switching to the Bravia TV. Switching back/forth usually cures. Hoping too it's just a driver glitch 'cause everything else is working great.
Possibly - I've just ordered an EMI-suppressor grade HDMI>HDMI cable to rule out the existing DVI>HDMI one (although this worked perfectly with the old 8800GTX).
@DarkWhisper:
To find out if there is a fault in either of your cards, try removing one and run the pc for a few hours to see if you can replicate the fault, then try the other card on its own...
If the fault does not occur with either card, then it maybe a crossfire/driver issue, however, if you can replicate it with just one of the cards, then you may have a faulty card.
Aye, normal output (2m DVI>DVI) to the 2408 is fine, haven't seen any glitches.
