, although memory voltage adjustment is rumoured to be coming in the next Trixx update(if it works on the DD), so it might change things a little.I got mine before the voltage lock started happening. I have mine at 1100/[email protected] temp gaming don't pass 66c and vrm never pass 70c.
If it's the cheap DD, then that's why.
Mine does 1100/1400MHz stable with a little voltage, regardless how much voltage goes in, the core won't go past a not too stable 1150, it's not a temp issue on the core sitting under an AC Extreme, before it topped out@1GHz using stock DD cooler.
The memory-forget about it, although memory voltage adjustment is rumoured to be coming in the next Trixx update(if it works on the DD), so it might change things a little.
Cheap vrms/flawed cooler(zero air vrm cooling) on the DD holding it back imo, but can't complain tbph, it's way, way cheaper than the rest of the 7950's, +100Mhz for up to £85 extra, I'll just be happy with what I got.
@dp,
Can you get the vrms cooler ie bump the cooler to 100% to take the heat away quicker from the vrms?
That's when stability started to become an issue, it was the vrms causing it as I could keep the core easily under 60c.
I realise 100% is terribly noisy, but it would let you know if it's a heat issue or that's just your lot.
Unless your not bothered of course and happy with what you get.![]()
how did you keep at temps of around 60! thats crazy cool
mine is running at 60 idle.... thats not right now is it
ive turned the fan up to 100 to bring the temps down.
@dp,
It's fine, the DD cooler is on a low rpm setting, it's stock fan profile is aimed at low noise nuzik.
XFX don't do oc software.
The AC Extreme keeps temps in check.![]()
