XFX 850W POWER SUPPLY ONLY £124.98
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys, we have great pricing on the latest 850w XFX Power Supply with SLI/Crossfire support. This PSU provides a super high-powered +12 Volt single rail which is ideal for overclocking and gaming.
XFX 850w Black Edition Modular Power Supply @ £124.98 inc VAT
The XFX Black Edition 850 watt modular power supply gives you the power you need with a brilliant combination of form and function. Giving more than just life to your PC, this power supply allows easy cable management with modular connectors which helps increase airflow. With tight voltage regulation and high efficiency operation up to 88% (80 Plus Silver) this power supply will give you exactly what you need to keep your gaming charged and ready.
- 850W of continuous power at 50°C
- 80 Plus Silver Rating
- SLI Ready
- Detachable Modular Cables
- High quality Japanese brand capacitors (105°C)
- Tight voltage regulation (±3%)
- High efficiency operation up to 88% (80 Plus Silver)
- Single, high power +12V rail (up to 70A/840W)
- DC to DC Voltage Regulator modules for +3.3V and +5V
- Solid polymer caps provide enhanced reliability and stability
- Quiet 135mm ball bearing fan provides superior cooling
- Supports multiple high-end graphic cards (SLI & CrossFire)
- Active Power Factor Correction
- 5-year Limited Warranty
Only £124.98 inc VAT.
ORDER NOW
Did they ever fix the overload shut off problem with these? I.e. they didn't shut off but went bang instead.
Not seen any info on that, do you have a link?
From the reviews I've seen this is a very high quality PSU, trades blows with the corsair HX units.
The PSU's are very good with great reliability and safety features. They are a great looking design which will/does appeal to the enthusiasts.
Yes, it was in particular reference to this review, I believe it's the same product, if not, my mistake.
It was a topic of much discussion at OC3D.
Obviously they were testing it to the limit, which almost any consumer is unlikely to, but it's not reassuring buying a product with a possible problem like that.
Well you would think that they (XFX and Seasonic) would sort the overload problem. I mean, you dont hear about anything like this happening to any Seasonic units and it wasn't good publicity for them. Would be nice if someone knew/could find out :)
