XFX GTX260 issue.
6 Jun 2009
London
Hi folks.I just got hold of a XFX GTX260 Black Edition and I have a very annoying problem.The image seem blurry no matter what refresh rate I select and this happens in games aswell.So got any ideas on what it could be?
I have no problem running any of my LCDs - including a 2048x res one - off VGA - sure DVI looks a little more crisp but you wouldn't call the image on VGA blurry.
Its possible its not actually using native res even tho it says it is - does the OSD menu on the panel show the resolution the display is running at?
Also have a look here in the nvidia control panel...and check which scaling option is ticked..
In the OSD it shows 1280x1024@75 .And I tried that thing in the nvidia control panel but the only problem is that for me it doesn't show those options.It only shows something about changing the position of the screen.
