XFX R9 280x Voltage OC nightmare
26 Apr 2014
Hi everyone.
From a while I trying to oc voltage of my gpu. On the box and official website it is specified that voltage is unlocked. All tutorials MSI Afterburner using old versions of that program ( 3.0.0 ) . On the new version ( 4.1.1 ) voltage slider is locked. Any idea how to do it?
Thanks
Hi everyone.
Thanks
Hi. XFX may have a different definition of unlocked than you think. I have seen them say that unlocked means the max voltage is already being used and you can't actually adjust it. How true that is I do not know, but a big complaint I've seen for XFX. Doesn't mean there isn't a way around it... just makes it harder.
I had the same problem with my XFX R9 280x DD Black, the only program which worked for changing the voltage was Sapphire Trixx. I could never get MSI Afterburner to change the voltage.
