** XFX XTR 750W & 850W MODULAR NOW IN STOCK **
OcUK Staff
26 Nov 2014
Stoke
We've decided to introduce the XFX XTR 750W and 850W 80+ Gold Modular PSU's into our range at competitive pricepoints. These are rebadged Seasonics and represent excellent value for money for the spec you are getting, along with coming with a 5 year warranty as standard.
XFX XTR 750W '80 Plus Gold' Fully Modular Power Supply @ £89.99 inc VAT
Designed for serious gamers and DIY professionals, the XFX XTR Series 750W Full Modular 80 Plus Gold power supply delivers the clean and stable power required for demanding gaming rigs and workstations. A single strong 12V rail flexibly routes the maximum available power to the parts, enabling you to maximize power usage and making setup easy.
It's also been awarded the 80Plus Gold certification for its high power efficiency, and is also designed for NVIDIA SLI and AMD Crossfire multi-GPU systems, making it a perfect solution for hardcore gamers. Its modular design reduces cable clutter. And the large fan delivers silent cooling, so your computer and PSU can operate at peak performance.
Features
- EasyRail™ Plus Technology allowing plenty of wattage headroom to handle your devices
- Hybrid Fan Control allowing the power supply to operate silenty until it reaches 20% load or 25°C
- Ultra Quiet Fan Design
- Ultra Voltage Regulation Design
- Haswell Ready
- AMD Radeon CrossFire Ready
- NVIDIA GeForce SLI Ready
- Multiple PCI-E 6-Pin and 6+2Pin connectors
- True Wattage guarantee
- 80 Plus Gold certifying 90% power efficiency
- Extreme heat tested capacitors
Specifications
- +12V Rail Outputs : Single
- 100% Tested and Verified : Y
- ATX12V 2.2 & ESP12V 2.91 Compliant : Y
- Maximum Wattage (W) : 750
- Modular Cables : Y
- Performance Category : Enthusiast
- UPC Number : 778656058804
- CrossFire Ready : Y
- SLI Ready : Y
- AC Input Current (Arms) : 9.5A-4.5A
- AC Input Frequency (Hz) : 50/60 Hz
- AC Input Voltage (Vac) : 100-240
- Efficiency @ Typical Load : Up to 90%
- Energy-Efficiency : 80 Plus Gold Certified
- High Reliable 105°C Japanese Capacitors : Y
- Solid State Capacitors : Y
- Tight voltage regulation (±5%) : Y
- Max -12V Output Current (A) : 0.3
- Max +12V Output Current (A) : 62
- Max +3.3V Output Current (A) : 20
- Max +5V Output Current (A) : 20
- Max +5VSB Power (W) : 2.5
- Modular ATX12V / EPS12V : One 4+4-pin, One EPS 12V 8-pin
- Modular FDD : 1
- Modular Motherboard Connector : 20+4-Pin
- Modular Peripheral : Up to 6 Connectors
- Modular SATA : Up to 10 Connectors
- Active Power Factor Correction (PFC) : Y
- Over Current Protection (OCP), Over Power Protection (OPP), Over Temperature Protection (OTP), Over Voltage Protection (OVP), Short Circuit Protection (SCP), Under Voltage Protection (UVP) : Y
- Cooling Fan Size (mm) : YES; 135mm Fluid dynamic Fan (Black)
- Master Carton Dimensions (cm) : 43.0 x 29.5 x 34.0
- Master Carton Dimensions (inch) : 16.93 x 11.6 x 13.39
- Master Carton Weight (Kg) : 11.72 est.
- Master Carton Weight (lb) : 25.84 est.
- Package Dimensions (cm) : 31.9 x 21.0 x 16.3
- Package Dimensions (inch) : 12.55 x 8.26 x 6.42
- Package Weight (Kg) : 2.76 est.
- Package Weight (lb) : 6.08 est.
- PSU Dimension (cm) : 8.6 x 15.0 x 17.0
- PSU Dimension (inch) : 3.4 x 5.9 x 6.7
- Units per Carton : 4
Connectors
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £89.99 inc VAT.
ORDER NOW
XFX XTR 850W '80 Plus Gold' Fully Modular Power Supply @ £99.95 inc VAT
Designed for serious gamers and DIY professionals, the XFX XTR Series 850W Full Modular 80 Plus Gold power supply delivers the clean and stable power required for demanding gaming rigs and workstations. A single strong 12V rail flexibly routes the maximum available power to the parts, enabling you to maximize power usage and making setup easy.
Features
- Haswell Ready
- DC to DC Converter Design
- Conductive Polymer Aluminum Solid Electrolytic Capacitors
Specifications
- ATX12V 2.2 & ESP12V 2.91 Compliant : Yes
- Maximum Wattage (W) : 850
- UPC Number : 778656058811
- CrossFire Ready : Yes
- SLI Ready : Yes
- AC Input Current (Arms) : 11A - 5.5A
- AC Input Voltage (Vac) : 100 - 240
- Active Power Factor Correction (PFC) : >0.95 at full load
- DC Output Voltage Regulation : ±3%
- DC to DC Converters (+3.3 & +5V) : Yes
- EZ Grip Connectors : Yes
- High Reliable 105°C Japanese Capacitors : Yes
- Solid State Capacitors : Yes
- Max -12V Output Current (A) : 0.8
- Max -12V Power (W) : 6
- Max +12V1 Output Current (A) : 70
- Max +12V1 Power (W) : 840
- Max +3.3V & +5V Combined Power (W) : 125
- Max +3.3V Output Current (A) : 25
- Max +5V Output Current (A) : 25
- Max +5VSB Output Current (A) : 3
- Max +5VSB Power (W) : 15
- Max. +3.3V & +5V combined power (W) : 125
- Wattage(W) : 850W
- Over Current Protection (OCP), Over Power Protection (OPP), Over Temperature Protection, Over Voltage Protection (OVP), Short Circuit Protection (SCP), Under Voltage Protection (UVP) : Yes
- Cooling Fan Size (mm) : 120
- Intake Fan: Airflow (CFM/min) : 80.5
- Intake Fan: Diameter (mm) : 120 x 120 x 25 mm
- PSU Dimension (cm) : 8.6 x 14.0 x 16.0
- PSU Dimension (inch) : 3.4 x 5.5 x 6.3
- RCM : Yes
- CB : Yes
- cTUVus : Yes
- TUV: Yes
- CCC: Yes
- FCC: Yes
- CE: Yes
Connectors
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 6x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £99.95 inc VAT.
ORDER NOW
Very good PSUs, but would wait for a TWO on these as £5 off a G2 750W for the XTR 750W is a bit too close for me personally simply for the 10 yr warranty
Understandable, however some people just want a Seasonic PSU and this provides that quality at a much better price than Seasonic's own products :)
Cant recommend the xfx 850w. Fan failed after only a couple of months and developed annoying electric noise after about a year (not coil whine).
Think I was unlucky like you, my 650w makes an electric noise when the PC is shut down but PSU is still switched on (rocker switch on). Luckily it's not noticeable if you're further than a metre away :)
So, now that more XFX psu's are being stocked I really hope that their abysmal customer service has improved. A 5 year warranty means nothing if they still mess people around and reject rma's for no good reason.
My old XFX 650w fan died after about 18months, and XFX warranty was a joke. It was terrible, I ended up giving up and throwing the PSU in the bin and just buying a new unit.
