Like what?You can tell from other stats how a game is going if you aren't watching it live
No, it isn’t. There’s an obvious point to betting odds. A trade off between enticing punters to gamble and losing money, that’s the entire “game”.This is like saying "whats the point of odds for betting companies, things don't work out like they should all the time".
You just need to understand a little about statistics to appreciate it.
Possession, shots, shots on target, corners conceded, bookings, etc., etc. Hard to believe you couldn’t have guessed this.Like what?
I find xg is much better at telling you how the game actually went, than any of the above, with the possible exception of "Shots on Target" but even then.Possessions, shots, shots on target, corners conceded, bookings, etc., etc. Hard to believe you couldn’t have guessed this.
Ah yes .. what kind of forum are we on at the moment??? an overclocking computer bits shop forum.. does it get more nerdy?!?What the sport and enjoy it for what it is. Stats are for the nerds.![]()
Your last point is what I was really getting at. A lot of fans don’t understand much about it so say things after a loss like, “Well, the xG was x for us and y for you, so we should have won”.
Chelsea had no bookings last night, they must have absolutely dominated us then.Possession, shots, shots on target, corners conceded, bookings, etc., etc. Hard to believe you couldn’t have guessed this.
two teams could have the same shots on target, one team both shots from 25 yards.. (xG 0.1) and trickled to the keeper, the other from inside the 6 yard box, (xG 1.4) which caused great saves..
I would definately say the second team had the better of the game..
I personally like xG.. as long as you take it for what it is..
Like most stats in a football match, it’s never wise to rely solely on one stat alone to tell you how a game went. You need a much wider range to form an accurate opinion. Hence why I said further up, though jokingly, that’s it better to leave the stats to the nerds.xG doesn’t tell you that at all.
