Hi guys
Just trying to install the drivers fresh from the CD from the original box...
Typically Creative drivers they say "Setup is unable to detect a supported product on this system" then you just have to cancel the install. That's it..
I have various other versions of the drivers, that I have found on the net, and they do the same thing...
Funnily enough I had this same issue on my Audigy 2 on my old PC, you think Creative would have sorted their drivers by now...
Any help much appreciated !
Thanks
Thanks
