Xonar DX - DSP Modes not working
31 May 2005
Nottingham
Say I want to enable the Music DSP mode, I still only get audio from the left and right channel, nothing from the centre channel.
Audio Channel - 2 channels
Sample Rate - 96KHz
Analog Out - 5.1 Speakers
The modes do nothing :(
Any help peeps?
Many thanks.
No, that is the idea, it is supposed to "Upscale" 2 channels.
Windows is set to 6 channel output and speakers test OK.
Setting anything above 44.1kHz as a samplerate both in Windows and the Xonar driver panel causes the DSP settings to not work apparently.
Tbh though, personally I wouldn't bother with the DSP settings in the first place but I like my audio pure.
Setting back to 44.1khz will most likely solve your issue although degrade your quality if you are on Vista or 7.
See here for more details.
Great post, thank you.
You are spot on.
I will stick with 96Khz and forego the DSP Settings. I have a pair of Z5500 so can do it with them if needed.
I assume the GX feature is not affected?
