Xonar DX, plus need help with MKV DD/DTS 5.1 output
24 Oct 2002
Portsmouth
Hi all
I've just got myself a bluray home cinema system for my room. However for boring technical reasons relating to my older generation TV I cannot use the HDMI on my Geforce.
Sooooo I'm using a optical cable from my Xonar DX to my Samsung home cinema. So far so good. In the Windows 'Sound' control panel I can do a dolby 5.1 / DTS 5.1 sound test that confirms all speakers are usable and will play back sounds.
However when I play back a MKV with a DD/DTS 5.1 sound track in either media player, media player classic or media portal all I can is stereo sound :confused:
I've turned on SPDIF in the Asus control panel, and even in there if I do a speaker test the only options that make any noise are the front left and right speakers. Am I doing something wrong?
Aha, don't worry I've found the answer. In the Shark Codec pack I have installed 2.0 Stereo output is the default chosen option. I changed this to 5.1 and it worked fine :)
ive got the same problem...cant get it to work....ive installed codecs but cant work out how to change from 2.0 to 5.1 option like you have...any ideas thanks
Stonedofmoo Aha, don't worry I've found the answer. In the Shark Codec pack I have installed 2.0 Stereo output is the default chosen option. I changed this to 5.1 and it worked fine
