I have had this amp. Very good amp with the hd650.
I found the bass was more natural and pronounced, and gave them a more natural sound.
I regret selling it.
Did you use the PSU1 with it?
How do the HD600's compare to the 650's guys? In amplification terms. Are the HD600's as demanding?
I imagine that there's not a lot in it. The drivers are very similar.
I currently use an Essence STX with Denon D7000s, HD600s and Ultrasone Pro900s. The hd600 seems to be the hardest of the three to drive.
They all sound good to me amped by the STX, but I can't help wonder if they could sound better with a dedicated HP amp.
However, like with most audio gear I'm sure the law of diminishing returns will come into play. Will an expensive desktop HP amp really be such an improvement over the STX to justify the cost?
Through my favorite headphones, Sennheiser's HD-650, I was consistently surprised by the quality of the Xonar soundcard's output. Yes, in comparison with the CEntrance DACport USB headphone amplifier ($395), which I reviewed in June (p.99), the highs weren't quite as silky smooth; and my reference Benchmark DAC1 ($995), fed with the Essence STX's digital output, offered tighter, deeper lows and a generally greater feel of dynamic swings. For example, Mark Flynn's snare drum on Attention Screen's Live at Merkin Hall (CD, Stereophile STPH018-2) exploded from the Sennheisers as it should when the headphones were driven by the Benchmark; driven by the Essence STX at the same level, the drum sounded as loud, but without quite the same jump factor. The low frequencies did have a greater feeling of power and drive than they did with the DACport, however, and backgrounds were silent, with no noise interference from the PC. Overall, the Essence STX's headphone output was better than you would expect from so affordable a product.
I note that Stereophile recently updated their review of the Essence cards to include performance as a headphone amp (using HD650s).
http://www.stereophile.com/content/asus-xonar-essence-ststx-soundcards-follow-september-2010
Regarding Creative X-Fis, the only one from the original lineup to feature significantly improved analogue components was the Elite Pro. Everything else down to the Xtreme Music and Xtreme Gamer (when it appeared later) was basically the same sound quality, with the differences being features, X-RAM or accessories.
These just arrived today and OMG!
The sound quality is absolutely STUNNING!!!!
I can stop listening to my record collection, but the problem some MP3's are not standing up to the scrutiny!!
WHat is best to re-rip audio collection? FLAC or AAC on itunes?
Cheers
I think the STX is good enough for the 650's to be honest. I have a Graham Slee Solo Ultra Linear headphone amp which cost almost as much as my GPU's. There isn't what I'd call a huge difference using this amp compared to the asus with the HD650 or HD800 cans in my experience. At least with Rock music. The Asus is definitely up to the job. I've also tried both sets of cans with the headphone output on my Marantz PM6003 amp. And again not a lot of difference comparing this amp and the asus. Since then I've moved the headphone amp into my "sound" room for dedicated listening with the HD800's. I'm using the Asus/HD650 combo you have for gaming in dolby headphone mode, and the rca out's from the Asus goes into my marantz amp for when I uses speakers.
So personally I'd stick with the HD650/Asus combo. Also if you get a dedicated headphone amp, the only way you will be able to use dolby headphone mode for gaming with the HD650's is if you output the Asus's headphone output into your headphone amp rather then the more traditional rca outputs into the amp.
One recommendation I would make if you are sticking with the Asus is to change the OPAMPS. It takes all of 5 minutes and can improve the sound especially with headphones. Or at least it changes the sound. You can order sample opamps for just the cost of postage from National SemiConductor. I replaced the pair of JRC2114 chips in the I/IV section (that's responsible for the headphones) with a pair of LME49720's which reduced the slight harshness in treble when using headphones, and the LM4562 (which affects the RCA output) with an LM6172IN which provided more accurate directional cues when gaming and better imaging.
The 2nd last post in this thread explains how to replace them. I used a long noses pliars.
http://headphones.com.au/forums/vie...sid=19fee4a405760639d6119efd8c4c8dfd&start=75
Well that's really good advice thanks, I think for the moment I am happy with the essence and the HD 650's, I haven't got loads of money at the moment so I'll stick with what I have, maybe when I am feeling a bit more flush I will try out and amp and see how it performs next to the essence for myself, until then I am really enoying the combination that i have.
They've spent the last 6+ months in their box, as I prefered my D2000s. I was going to flog them on, but listening to them just now I'm not not sure I can.
