Xonar U7 Replacement
26 Oct 2013
Leicester
Hello guys
I am on my second Xonar U7 which has again crapped itself with the same stupid blinking LED error so I am not going to be going onto a third unit. I am after a good replacement now. I use a pair of HyperX Clouds and also AE Aego M 2.1 speakers connected via RCA.
Does anyone have any relatively cheap (<£80-90) suggestions for a replacement? When the Xonar works it's great as it allows one button swap from headphones/speakers etc but the build quality seems to be useless. USB or PCI/E is fine
Looks like Asus forgot to give it reset switch...
Sound Blaster X-Fi HD would be pretty similar external sound card.
But switching between headphones and speakers is apparently done in control software.
Sound Blaster Z would have SBZ Switcher for automating that manual change to to hotkey
https://www.overclockers.co.uk/search?sSearch=sound+blaster+z
https://forums.guru3d.com/threads/s...s-headphones-mode-switching-available.381416/
Lowermost PCIe slot would be best for keeping sound card away from heat of GPU and minimizing risks of EMI.
