I've been doing some research and I'd like to check that my understanding is correct.
Because my windows is 32bit it can only address 4 Gig seperate address (2^32).
Now some of these addresses are needed to talk to hardware - PCI cards, mobo bits, NIC, Soundcard etc.
Also some addresses are needed to address video memory - I assume the amount put aside depends on the amount of video memory you have - my GFX has 320MB.
Once all those addresses have been sorted out, what is left can be used for RAM.
This seems to be reported as somewhere between 2.5GB and 3.25GB.
Have I got it correct?
Thanks,
Nigel
Thanks,
Nigel
, I think I've read that using that switch can cause problems with some programs and should be uneccessary unless used for specific purposes
