xp home/pro question
1 Jun 2005
Kent
Just to confirm what ive read online, xp home allows multiple cores as long as they are on the same cpu (like a core 2 duo) right? or is pro needed to run a multi core (single cpu) system?
A dual core CPU and XP home will work just fine. If it's an AMD processor, you'd be wise to install their Dual Core Optimizer, though.
I'd never experienced or even heard of such problems until now. Thanks for the heads up.
Off topic - I take it you're in the Hull Road area of York?
