Hi, ive just built an i3 rig and i cant for the life of me get an OS on it.
Quick specs
i3 530
Gigabyte GA-H55M-UD2H
4GB OCZ Gold DDR3
Samsung F4
Corsair CX 400W PSU
Now i started to install XP and got as for as loading device drivers and id get the irql_not_less_or_equal BSOD, i swapped the RAM out for 1 stick of mine and still got the same issue.
After a bit of research i got an XP disc with SP2 on it as i read the XP only discs were a common problem with driver errors.
Now i don't even get that far, it loads the files and before it gets to the windows screen it BSOD's with a hard drive/hardware error.
Ive tried all sorts in BIOS, from setting RAM timings and voltage, ACHI, etc etc and i keep hitting the same point. Ive tried an IDE drive, ive tried Vista and Windows 7, Vista and 7 just freeze before any windows screen and XP BSOD's.
Im properly out of ideas now, do i have faulty hardware? I will call OCUK and see what they say but id like to know if there's anything ive overlooked.
This isn't the first system ive built, im running a watercooled i5 system but that doesn't mean ive missed something totally obvious!
Thanks
Quick specs
i3 530
4GB OCZ Gold DDR3
Samsung F4
Corsair CX 400W PSU
Thanks
