Hi, recently reformatted my old laptop, tried to install XP onto it, during the install it is unable to copy certain files. I copied the same files onto another disk from another computer and it will not copy them from there either.
I was told that some xp disks have a limited number of uses but the version I'm using is a corporate version and has been used over 100 times with no problems.
The files that wont copy are :
samsrv.dll
wiashext.dll
win32k.sys
Any help will be much appreciated.
Thanks.
samsrv.dll
wiashext.dll
win32k.sys
Thanks.
