XP machine restarts whilst booting up in normal/safemode. What would you do?
Don
21 Oct 2002
Parts Unknown
Quite often, I just backup their stuff, use their xp disc and format = 'new pc'
Really can't be bothered this weekend to do this.
I've tried this in recovery console, but didn't work..
fixboot
fixmbr
doing a chkdsk /f now
What would your next move be?
will try that if chkdsk fails
it's the sort of pc that could do with a full upgrade..
1ghz, 1gb ram, 120gb hard drive
With an issue like that, I've found it is generally the quickest way.
Can get a build done in under 2 hours, and then just leave it so it to pick up the updates.
Although after trying the recovery console, I'd do a memtest.
chkdsk fixed it
windows is slow, MASSIVE icons, will clean up best I can
just going to semi fix it, and suggest an upgrade when I give it back (for a family member)
