Caporegime
- 17 Oct 2006
Hi
Ok strange one this (for me anyways) ... My little girls computer wont startup... gets as far as the Windows XP Pro flash screen and appears to load then goes to the black screen giving startup options of starting in safe mode etc and also states that new software or hardware may not have been installed correctly and thus resulted in windows not being able to start. If I go into safe mode and startup then select system restore and a previous safe date (though I dont what is as nothing was installed hardware or software) the computer powers down but doesnt restart again ... just returns to orginal black error screen as mentioned before ... once I again select safe mode I then get the message on bootup that system restore has gone to the selected date ... but nothing starts upon fresh reboot. Anyone got any ideas? The only thing I know was done was a camera attached to download photos BUT this has been done on numerious occasions without problem. Thanks
We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this.
If your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders, choose Last Known Good Configuration to revert to the most recent settings that worked.
If a previous startup attempt was interrupted due to a power failure or because the Power or Reset button was pressed, or if you aren't sure what caused the problem, choose Start Windows Normally.
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Last Known Good Configuration (your most recent settings that worked)
Use the up and down arrow keys to move the highlight to your choice.
Seconds until Windows starts: 30
The first time I came across this message, the seconds counted down, I tried Start Windows Normally, and it looked as if windows was booting up for a second or two (the black and white progress indicator bar came up), then a blue screen flashed up really quickly (I think it may have been the scandisk message). Then the computer rebooted to the above message again. This time, the seconds did not count down, it remained on 30. I am able to arrow up and down.
I tried Safe Mode, Safe Mode with Networking, Safe Mode with Command Prompt and Last Known Configuration but windows reboots each time.
Safe Mode
just as well its a full version. I'll let you know how I get on thanks again !
All programs /software appears to be still here and fav listings in explorer so I think Ive gotten away with it. I will take your advice and purchase a second harddrive (external usb type) so all the pictures can be stored (backed up) safely. Thank you once again for all your time and efforts and advice Cheers!
