XP Video (Codec??) Problem
11 Dec 2002
Not sure if anyone has come across this before but I am having problems playing video files (either in IE or winamp / wmp etc)...
Basically the system grinds to a halt and 100% cpu usage occurs (although from task manager you can't tell what is hogging the resource).
Done a bundle of AV scans / Trojans but nothing appears. I have also forced WMP uninstall and tried a later version. (Also tried this with winamp / Quicktime) but nothing..
Is this a known virus or problem??
Thanks Steve
I should do ... as I reinstalled all the core programs. I did also try one of the those "all codec" things but it made no difference.
I don't get an error telling me of an unkown codec ( e.g. mp4) but it just grinds to a halt and kills the pc.
Tried both of those - no difference..
Changed gpx drivers ( just in case ) nothing...
wierd thing is that no process ( other than task manager ) is showing as holding the CPU - so can't really tell whats going on...
azaniah said:
Anyone know of a free process trace prog for XP Pro?
Might be able to track the culprit down that way
It is a Codec problem to me, from what you are describing. Uninstall all prevoius codec installs, try a codec pack Mega-Codecs (best imo) or even K-Lite, they should work, if not sounds like a corruption somewhere within the Setup....
