- 19 Nov 2005
Hi
Im having a few problems with my PC.
It all started when i tried to reinstal win XP on a dual boot system. For some unknown reason XP removed my Vista files and i could only use XP.
Problem #1
After reinstalling both operating systems i began having problems with starting up my PC.
When i start my PC it just gets stuck on the BIOS EVGA logo screen. At this point it just locks up and does nothing.
Occasionally if i hammer the TAB key i can get into the POST screen, at this point it just gets stuck on 'Detecting SATA devices'
i can also sometimes get into the BIOS menu.
On occasion the PC will randomly manage to get past this stage and boot up. I thought this problem would be caused by the dual boot and i have removed
Vista. Unfortunatly this did not solve the problem.
Any idea's how i might get this fixed?
Problem #2
After removing Vista from my second HDD i still get the dual boot menu asking me to selected XP or Vista when my PC manages to start up. I can only imagine that this means some how vista
files were installed onto my first HDD.
Does anyone know how i might find these files so that they can be removed?
Thanks for your help
-Magnumwolf-
Problem #1
Problem #2
-Magnumwolf-
