- 17 Apr 2009
- East Northants
Hi all.
Im looking at replacing the stock CPU heatsink on my XPS 420, as it will get in the way of pretty much any of the decent coolers that i could find for my 9800gt.
Am i right to assume that whatever CPU cooler i purchase, i will need to remove the motherboard and change the CPU heatsink mount on the back of the motherboard? Or are there some coolers that can fit straight in the place of the old one?
Cheers for listening
Jack
Jack
but then thin wouldnt go past the post screen therefore with a bit of DIY i used a molex to 3pin fan adapter plugged in the cpu fan to the psu directly had to snap a plastic guard on the adapter. then plugged in the old fan in and strapped it to pull air in the case. be prepared
