XPS dell power jack.
4 Feb 2006
nottingham
The power port on my m1530 is very loose, basically it holds the pin fine but if any pressure if applied to the cable it will come out. Its been like this since I purchased it unfortunatly it was over 1 year when I got it, which hasnt got any worse.
If its now used on a knee it might fall out if you reach for something. It has to be used on the desk so the lead is supported. It is useable but alittle annoying.
After speaking with dell, they have said they would class this as 'faulty' and want £400 for the motherboard. :eek: They qouate this is wear and tear, I consider this to be a joke a port should be designed to be plugged and unplugged! I know I could buy a refurb boad for 1/3 of this but this is not the point.
Without this tread turning into a massive can of worms, isnt there a Eu law that something should be designed to last longer than 1 year, regardless of thier warrenty. Nothing should wear this quickly, therefore it is defective. I qouted this to dell and the agent promptly arranged a callback for me tommorow from a customer care team, however I am not sure if I can force anything to be done from here.
A photograph of the offending port is below: It looks perfect with no expansion, cracks or signs of misuse.
Is there any way I could maybe wangle a free repair from them, I have seen loads of complaints about this problem but no one has followed up on wither they have given in.
I have the same laptop in the same city... :)
I think the power cord in mine has always been a bit loose? even when it was given to me new, sliding the notebook around on my desk a few times/repositioning it often leaves the cord falling out, must be bad design to begin with followed by a touch of wear and tear too. Might be hard to fix with even a new board?
I just bought a new adapter for mine (lost the old one) will see if this is a slightly better fit at work tomorrow, I was thinking perhaps if it was 0.5MM wider it'll grip better inside? oh the new adapter is a new style, will check if its different.
I would be very helpful if you could let me know how you get on. Regarding the design Dell flatly deny its a design fault, i do however, the person that owned mine looked after it really well and after 13 months of use its loose. Dell say that I have worn it, which I think is absolutly ridiculous.
If you could forward me the model number or any part numbers that would be great. (For your replacment psu) if it works for you I`ll look into getting one.
nopeski
its works laptop not mine, and it's not that bad a problem as yours by the sound of it.
but can see it going that way after a while, yeah bad ass design :(
