Hi all,
Got an XSPC Raystorm D5 kit from Overclockers and it works fab. Temps are pretty low and I've got this loop:
Rad -> Pump -> CPU (I7) -> GPU (ATI 7950) -> Rad
Coolant is standard clear coolant (can't remember the brand) and a bit of distilled water mix.
My problem, if it is even a problem is that under load my pump is making a gentle squeaking noise as if there is a mouse in there. It's not loud, doesn't appear to affect performance and is only annoying when the games are quiet.
Is this normal for a water cooled system?
I had this problem ages ago with my '72 Mustang and it turned out to be air trapped in the cooling system that the bleed wasn't getting out properly - is this possible and if so how do I check for trapped air in a PC based cooling system?
Thanks for your help,
Blitz
Blitz
