My temps were creaping up and I knew I needed to clean out my loop (could see stuff floating in the tubes
) so I've finally added this block to my loop. And dispite the lack of smooth sides this block if fantastic in lower presure loops like mine. I must also say how much better the mounting hardware is than the GT - longer bolts, locking nuts and thumb turn bolts made it much easier to install. also took the opertunity to do a few more changes while my loop was drained.
1) Flush loop / remove all block and clean with mains pressure water (hose)
2) Swap Apogee GT for XSPC edge
3) Retain theralright backplate and use XSPC mounting hardware.
4) Swapped plastic mounting hardware of maze4 to metal bolt,washer,locking bolt, (block), washer, spring, bolt, locking bolt (was inspired by edge)
5) Added Alphacool SilentStar (lapped/AC5 sides of raptor prior to install in enclosure)
6) Cable tidy
A month ago
Res2 - Apogee GT (
[email protected]) - Maze4 (P35) - DS rad - Res2 = (47c cpu@100% ambient 23c)
Wednesday - notice the 7c rise in cpu temp evenn after lower clock
Res2 - Apogee GT (
[email protected]) - Maze4 (P35) - DS rad - Res2 = (54c cpu@100% ambient 25c)
The pins on my GT were even worse that I thought and filled with algee - not good
Yesterday
Res2 - XSPC edge (
[email protected]) - Maze4 (P35) - Alphacool SilentStar (36gb Raptor) - DS rad - Res2 = (43c cpu@100% ambient 25c)
4c lower than a month ago,
and adding the raptor into the loop
and a higher ambient. The flow meter on the Res2 is also spinning at lease +50% faster that a few days ago (if not faster then I've ever seen) confirming it's a low restriction block
All in all a very success rebuild, and recomended for Zalman Res1 or 2 upgrades
