fothsn said:What do you want to do to the file? Play it in a DVD player? Does the DVD player support Xvid/Divx file formats?
They are both forms of different video compression formats,
Daff_Duck said:Silly question but are the 2 the same format? Also if you do have an xvid film how do you burn it via burning software is as a data?
Sorry to ask such a simple question but if you could advise would apprecaite it
Energize said:They are very similar, both are mpeg4 ASP. Divx players will often play xvid files.
no_1_dave said:All DviX players can play XviD (or should be able to).
Some however wont play XviD if the Xvid has a "packed bit stream".
Download a program called mpeg4 modifier (under 1mb). You can load an XviD into it & check if the bit stream is packed or not. If it is you can untick the packed bit stream option & save it making the XviD fully compatible![]()
seriously though would someone advise
Energize said:It's not just packed bitstream, divx doesn't support quarter pixel or global motion compensation, iirc.
Lonewolf said:Always worth purchasing a DVD RW disc to check the file will play in your player before putting the file onto a DVD disc permanently. To answer your question, burn as data to keep your file as DivX/Xvid
