2 PWM 120mm, one 3 pin 140mm (2 for the CPU cooler, 1 for case). Seemed to run fine as far as I could tell. The wire was a complete mess however, made cable management a bit of a pain...
Re: 4pin Y splitter
YOUR BASKET
1 x Akasa PWM fan splitter (AK-CBFA04-15) £2.99
Total : £5.96 (includes shipping : £2.48).
Out of stock though.![]()
All mine are case fans.
The CPU cooler is a H100i running 2 120mm fans off the pump.
Thanks for the suggestions Danny, but that will not work. There is a subtle difference between 3 and 4 pin connectors. The 4 pin is wider and has the protruding pin futher out than the 3 pin.
That ASAKA connector has the 3 pin position but not 4![]()
