I'm trying to get an old style power supply (small fan at the rear) but all I can find is ones with large fans on the bottom and im hoping anyone out there knows of one that would fit the bill. The system in question has a solid metal shelf that the PSU sits on so a bottom fan would be completely cut off from any airflow.
It needs to have at least two 4 pin Molex connectors, one SATA power connector, 24 pin motherboard connector, 4 pin P4 connector and a FDD power connector.
Thanks you.
Thanks you.
