- 24 Apr 2007
- Southport
Well, after someone offered to buy the 416i of doom (lovingly known as the skip of doom, the shed, rotbox... etc) I got on the hunt for something a little more lively to replace it with.
So for £180, I give you...
It's a 1998 620ti, which has Tax and MOT. Aircon works, has a sunroof and a half leather interior! Also has the 4 electric windows plus a chavvy JVC stereo.
The 620ti has the 2 litre turbocharged Rover engine, running at 197bhp. This is fed through a 5 speed gearbox, with a TorSen LSD. Front wheel drive though.
Good bits:
- New gearbox selector rod, front brakes, oil and filter, etc
- Runs well, runs to full boost and shifts nicely!
- Comfy as hell
- Had a suspension refresh at some point, feels nice and tight
- All electrics work (
Bad bits:
- Downpipe blowing slightly
- Slight oil leak from cam cover, new seal is... £2.
Bit more of a bargain than my 400, comes with a Haynes and service history too. Sorted.
**** off away!
Good bits:
- Comfy as hell
)Bad bits:
**** off away!
woop.
