Looks really nice, Rob.What plants do you have there?
On a side note, I've just bought my new external filter, an aquamanta EFX 300. Will be setting that up today.![]()
Couldn't really name them all, but there are a few Amazon swords, including a Bleheri behind the bogwood that will hopefully grow nice and big in that corner. A couple of cryptos, a couple of Vallisnerias and Hygrophila's. Some others well. Quite nice plants. I got 4 Bleheri's from one pot, which is unusual as normally you get a max of two due to the size of the plant.
Put some fertiliser plugs in and dosing weekly with a good fertiliser weekly. Should be a proper jungle aquarium within 6 months.
23cm under the substrate, damn thats a deep tank you have
The ferts from there are expensive and weekly dosing might not be enough for the jungle you long for.
What lighting are you using?
Are you adding any form of carbon to the water column?
Have a look into EI (estimative Index) dosing using dry salts. Much more economical than pre mixed ferts and you can tailor make batches to your aquariums needs.
When it comes to anything to with aquarium plants I can wholeheartedly recommend aquarium gardens at www.aquariumgardens.co.uk
The plugs can be found under aquarium plant food and are called TNC plugs. They look like capsules with small balls in them. You just push about 23cm under the substrate with about 2 per square foot and they slowly release ferts.
The plants I bought were in magnificent condition. Healthy leaved and a rich green, not a bit of brown anywhere.
Can I just gauge an opinion here.
How do the aquarium owners on here fare with their tap water?
Is it OK. Is it too hard, soft, high PH, low PH, and if not right, what do you do to correct it.
Thanks.
right, I have a 180 litre tank that I need to move when I move house
luckily the house isn't far away only 5 minute drive
anyone got any tips?
Thanks.
That's Ok if you have an external filter that can closed off while chlorinated water is in the system. If you have a Juwel tank with internal filter, remove the filter baskets before filling or the chlorine will kill your bacteria and you will cycle again.
What ever you do, I would grab a small bottle of Seachem prime as your dechlorinater and add a capful every 48 hours for a week. That will protect your fish should there be any kind of spike.
