NV FX 5xxx card , forgot the actual model number, was a shocking card!!!!!
7950 gx2
I can still remember when we used to have these placed called a pubThe real question here is .. what the hell is a PUB![]()
ATI 3870, was ditched fairly quickly for a 4850, which was a much better card.
I had myself a Geforce 5800 which I think was an engineering sample as it had a massive blower cooler on it that I think was black, not like the copper jobbies I see pictures of in memes. The thing could clock like crazy, almost double the memory speed and the GPU clocks went pretty high too. Not the most sensible purchase and I didn't have it long before getting myself a 9800SE softmodded to a 9800pro.
I bought myself the 3870x2 pretty much when it released and I found it a pretty good card, not that many games made use of the Xfire capabilities but still good.
The x2 cards seemed to work pretty well back then, they actually had both GPUs on the same board if I recall correctly.
There was a window between the move from more primitive graphics techniques towards full unified shader/compute features where multi GPU generally worked pretty well - especially if you were handy with the profile tweaking tools and had half an idea how to optimise it yourself. The 7950GX2 also used a bridge chip so that more data was shuttled core to core rather than via the PCI-e bus and/or CPU which gave a small improvement (mostly ~5% but could be 10-15% in some cases) over multiple cards in different PCI-e slots.
when he got himself a Geforce 2 MX card thinking it was similar speed..
