Would it better to leave it plugged in if one is always next to a wall socket?
If the charging algorithm holds the phone at 100% it isn't good for the battery - hence why bypass power is a useful feature.
I've got a pixel 8 with bypass charging enabled and it only charges to 80%. I've started to leave the phone plugged in 24/7 except when I briefly pop out. When I return, I plug it straight back in.If the charging algorithm holds the phone at 100% it isn't good for the battery - hence why bypass power is a useful feature.
Do you use your phone in your hand while it's plugged in?I've got a pixel 8 with bypass charging enabled and it only charges to 80%. I've started to leave the phone plugged in 24/7 except when I briefly pop out. When I return, I plug it straight back in.
What a completely pointless 'feature', why would anyone charge their phone to 80% or whatever then keep it plugged in a socket.
Surprised it wasn't Apple that came out with it and tried to claim it's some amazing new thing.
Yes I do?Do you use your phone in your hand while it's plugged in?
You can disconnect it from the wall and take it out. Can you do that with a landline?It’s a phone plugged into the wall. It’s no longer mobile - it’s a landline.
It's pointless having any further discussion with you if you think you can take your landline wherever you go.Of course you can!
You're putting strain on the usb port.Yes I do?
Valid point but my cable is 3m long and sometimes it wirelessly charges.You're putting strain on the usb port.
I wouldn't that's for sure.
It's almost like some people have never heard of a hotspot or a tether?
?? I work from home 8 till 7pm most days -- I could just leave it plugged in and not ever worry about it.What a completely pointless 'feature', why would anyone charge their phone to 80% or whatever then keep it plugged in a socket.
These people are known as "product managers"It always amazes me with some of these topics how some people can't comprehend or allow for anyone doing anything different to how they do things and/or have different needs or use functions they don't, etc.
